malandraeliott
Jun 11, 2018Tutor
EX8000 Serious ethernet firmware bug in V1.0.0.126
In the latest firmware (V1.0.0.126) if you connect a computer to the ethernet interface on the EX8000 and then put the computer to sleep (in this case an iMac), the 5 GHz wifi signal on the EX8000 dr...
DexterJB
Jun 14, 2018NETGEAR Moderator
Hi malandraeliott,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Tezz001
Jun 15, 2018Aspirant
I’m also having this issue with the ex8000 dropping all my connections except it happens when I switch my PS4 on or off, I assume it’s the same process as putting a pc to sleep or waking it.
Can Netgear please provide us with a fix, and not just a “have you tried switching it on and off again?” Type response
