Photodocfl
Oct 10, 2021Tutor
EX8000 Speed Drop to 3MBS
My EX8000 has been working well for 2 years, but sudddenly the WiFi speed has dropped from 200+mbs to 2mbs. This has occurred on all WiFi bands. I have done several reboots as well as a hard reset....
- Oct 10, 2021
Yes you can download older versons of the firmware and install it manually. I'd recommend doing it over a hardwired connect. The .224 version is the one I'd recommend. I haven't seen much issues on it.
Oct 10, 2021Guru - Experienced User
What firmware version are you on?
Photodocfl
Oct 10, 2021Tutor
Firmware is V1.0.1.232
