Photodocfl
Oct 10, 2021Tutor
EX8000 Speed Drop to 3MBS
My EX8000 has been working well for 2 years, but sudddenly the WiFi speed has dropped from 200+mbs to 2mbs. This has occurred on all WiFi bands. I have done several reboots as well as a hard reset....
- Oct 10, 2021
Yes you can download older versons of the firmware and install it manually. I'd recommend doing it over a hardwired connect. The .224 version is the one I'd recommend. I haven't seen much issues on it.
Oct 10, 2021Guru - Experienced User
What firmware version are you on?
DEA_User
Oct 10, 2021Aspirant
I'm on 2.26.10.0.42 now for my model which is the previous release before the current. I believe the current version has bugs
- PhotodocflOct 10, 2021Tutor
Is there a way to re-install the previous FW version?
- plemansOct 10, 2021Guru - Experienced User
I downgraded the firmware from V1.0.1.232 to ....242 - Problem Solved! WiFi speeds back to 500+mbps.
Looks like V...242 has a bug.
