GBarG
Dec 23, 2021Aspirant
EX8000 unreliable after latest firmware
Since applying the latest firmware my connected my security cameras periodically lose connection. They reconnect after 5 minutes or so. I turned all of them off, after trying everything to fix them. F...
- Dec 25, 2021
Did you try the factory update?
Or the firmware downgrade?
nielsvds
Dec 23, 2021Luminary
You should take a look at the link states led colour when the disconnection happens. In the latest firmware update a security vulnerability was fixed: https://kb.netgear.com/000064481/Security-Advisory-for-Stored-Cross-Site-Scripting-on-Some-Router-Extenders-and-WiFi-Systems-PSV-2020-0256
Here you can read more: https://www.netgear.com/about/security/
Downgrading is also possible: https://www.netgear.com/support/product/EX8000.aspx (previous versions)
