GBarG
Dec 23, 2021Aspirant
EX8000 unreliable after latest firmware
Since applying the latest firmware my connected my security cameras periodically lose connection. They reconnect after 5 minutes or so. I turned all of them off, after trying everything to fix them. F...
- Dec 25, 2021
Did you try the factory update?
Or the firmware downgrade?
GBarG
Dec 24, 2021Aspirant
I don't notice the disconnection until after it's over, but I never see a problem with LED indications. I'm not going to try anything more to fix this because I seem to be ok without them. They were solidly working for a long time before the firmware update -- I just wanted to report the problem in case others noticed it also.
Dec 24, 2021Guru - Experienced User
Anytime I see an issue after a firmware update, I usually recommend a factory reset and reinstall.
Sometimes old settings can cause issues.
If that doesn't help, you can always downgrade the firmware. Always something to be said for stability.
- nielsvdsDec 25, 2021Luminary
The LED colour is important because that gives information about the signal strength. When the extender have a very poor connection to your router, you will get disconnects. That is why I mentioned it. But if it just happened after a firmware upgrade and you didn't move it, than the chances are high that is related to that upgrade.
