GBarG
Dec 23, 2021Aspirant
EX8000 unreliable after latest firmware
Since applying the latest firmware my connected my security cameras periodically lose connection. They reconnect after 5 minutes or so. I turned all of them off, after trying everything to fix them. F...
- Dec 25, 2021
Did you try the factory update?
Or the firmware downgrade?
Dec 24, 2021Guru - Experienced User
Anytime I see an issue after a firmware update, I usually recommend a factory reset and reinstall.
Sometimes old settings can cause issues.
If that doesn't help, you can always downgrade the firmware. Always something to be said for stability.
nielsvds
Dec 25, 2021Luminary
The LED colour is important because that gives information about the signal strength. When the extender have a very poor connection to your router, you will get disconnects. That is why I mentioned it. But if it just happened after a firmware upgrade and you didn't move it, than the chances are high that is related to that upgrade.
- GBarGDec 25, 2021AspirantI'm aware of that.
