GBarG
Dec 23, 2021Aspirant
EX8000 unreliable after latest firmware
Since applying the latest firmware my connected my security cameras periodically lose connection. They reconnect after 5 minutes or so. I turned all of them off, after trying everything to fix them. F...
- Dec 25, 2021
Did you try the factory update?
Or the firmware downgrade?
GBarG
Dec 25, 2021Aspirant
I'm aware of that.
Dec 25, 2021Guru - Experienced User
- GBarGDec 25, 2021AspirantTried reset, not downgrade. I'm not looking to fix this problem, since I'm doing fine without the extenders. My newer router is doing the job fine without extenders.
- schumakuDec 26, 2021Guru - Experienced User
Reads for me like two changes had applied on the network - a new (unspecified) router, and the EX8000 firmware update. Where the later one mainly includes some security fixes to avoid a possible command injection on it's management environment.
- GBarGDec 26, 2021AspirantI got the new router long before the extender firmware updates and all was fine for months. So the only one thing changed really
