Mark445444
Sep 21, 2020Aspirant
EX8000 Wifi Extender Blinking white lights on 10 month old product!!!!
10 month old product, started blinking all white lights acoss the front panel. Called netgear, want 60$ to offer assistance. I see alot of other people with this issue. Anyone able to fix???? Will b...
Mark445444
I was in the middle of typing a report when the lights just started blinking and lost connection. Factory reset 8 times. Called tech support and was told firmware issue and Netgear can fix but first I have to give Netgear credit card and purchase a 60$ service agreement.
Sep 21, 2020Guru - Experienced User
you could try recovering it using tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
