Riverwhip
Oct 07, 2020Tutor
EX8000 won’t connect
My EX8000 range extender stopped working the day after my hardware warranty ran out...wtf! It will no longer connect or reset, so I have no way to try to fix it. Any suggestions?
Oct 08, 2020Guru - Experienced User
Another thing you can try is its default ip address if not connected back to the router is 192.168.1.250
you can try hardwiring into the extender and access it using that ip address.
- RiverwhipOct 09, 2020TutorThanks for the suggestions! I’m going to work on it tonight. When I reset, all the lights blink as normal, like it’s trying to connect, then it just goes to one solid light for the 2.5Ghz
- RiverwhipOct 10, 2020Tutor
So, as soon as I cabled directly to the computer a "new setup" screen came up and walked me through. Now it's working fine. Thanks again for your help!
- plemansOct 10, 2020Guru - Experienced User
Glad to hear you got it up and functional!
