Riverwhip
Oct 07, 2020Tutor
EX8000 won’t connect
My EX8000 range extender stopped working the day after my hardware warranty ran out...wtf! It will no longer connect or reset, so I have no way to try to fix it. Any suggestions?
Oct 08, 2020Guru - Experienced User
Another thing you can try is its default ip address if not connected back to the router is 192.168.1.250
you can try hardwiring into the extender and access it using that ip address.
