AHR6912
Jul 30, 2021Guide
ex8000's aren't giving the results promised
Hi all, Using Spectrum Cable's 400 mbps service, from their modem to my RX500 wifi router, then hard wired to 3 different EX8000's, distributed through out the home in Access Point configuration as ...
- Jul 31, 2021Use this for more than one extender. Ie. Ex8000, 3 of them placed in farest areas in your home from the wifi router.
Order of install:
Reset extender, push on/off button to off, plug it in, keep holding down the reset button with a pin, then press the on/off button to on.
The green light is first, then turns to a red light, then it turns to a blinking red light, then release the reset button, the power light turns green.
Wait for the leds to stop blinking on the front.
Only the 2.4ghz will be on.
Turn the extender off then on.
Plug in a ethernet cable from the wifi router to the extender.
Far right front led, lights white.
Press WPS on wifi router ie. rx500
Then press WPS on the extender.
Wait a minute.
Go to a desktop computer, enter http://mywifiext/
The screen should say "new extender setup". Select it.
Agree
Answer questions.
Make a good user name. Not your email. Then password.
Next
Each unit has its user name and password.
Make each unit a unique name and pw.
User= abcd1
Pw=abcd1
When its time for the next unit repeat user name but change 1 to 2. Do the same for the unit's password abcd2.
Sign into your Netgear account.
Turn off, then on, the extender at this time. Again, wait for the lights to stop blinking, they will, I promise.
On the desktop.
Enter the user name and PW.
Go through the screens that you need to change.
Remember updates and wait times for various software interactions do take up a lot of time.
Remove access to the guest network or not.
Save
Check for firmware updates or not.
Go to status in the menu (left-hand top screen).
Wait for the screen to refresh.
If it doesn't, close browser, sign in to mywifiext again on a new browser window, like you did in the beginning.
You may have to sign in to your Netgear Account to add this unit.
After that.
Select Smart Connect or not.
Choose to enable AP or not.
Make changes, wifi channel, wifi speed, double-check PW in the middle of the screen, called the Access Point Network box.
Wait a long time for the interface to accept changes. You can always watch the lights on the extender. lol.
Next
Make sure you check the tiny box in the next window and hit continue at the bottom.
SUCCESS
Next
Ok done.
If at any time you can't move forward, restart the extender and the mywifiext address in a new browser.
Hope this helps anyone who needs more than one extender and connective signal with one SSID name for their WI-FI.
AHR6912
Jul 31, 2021Guide
Thank you for YOUR valuable information. It will take me a while to digest it. I will try it step by step to get these to work better. I mean, I'm getting great signal strength throughout the home the way I configured them presently. Just would like to know why my analyzer is reporting more (5) SSID's in the same name as I have units (3) configured. Thanks again. Valuable.
AHR6912
Jul 31, 2021Guide
Order of install:
Wait a minute.
Agree
Answer questions.
Next
User= abcd1
Pw=abcd1
On the desktop.
Save
After that.
Next
SUCCESS
Next
Ok done.
Order of install:
Wait a minute.
Agree
Answer questions.
Next
User= abcd1
Pw=abcd1
On the desktop.
Save
After that.
Next
SUCCESS
Next
Ok done.
