john_harrold
Jun 18, 2019Tutor
Exclamation point when switching between Extender and Router
When I move from the room where my router is located (EX8000) to a room covered by my range extender (R9000) I often get the following: An exclamation point over my wifi icon Message saying: "An...
Jun 18, 2019Guru - Experienced User
MIght have it backwards. The EX8000 is the extender and the R9000 is the router.
Firmware on both devices?
I'd start by making sure you've assigned a static ip address to the extender. Is it only on one device or do all your devices do it on the extender? You can set static ip address or ip reserverations to specific devices.
Support page for EX8000
https://www.netgear.com/support/product/EX8000.aspx
for R9000:
