deesigner2
Jul 14, 2022Aspirant
EXT 6120 keeps disconnecting from router
I have a new Netgear extender 6120. installed in a 1400 sq ft home. the router is two small rooms away. the samsung TV is new and in the MB. the ext is outside the MB in the short hall that leads to ...
deesigner2
Jul 15, 2022Aspirant
Connected via was. It finds cox router, tv gives me choices of 2.4 and 5.
I set it to 5. New Samsung TV.
It finds 5 but after a day or so, reverts to cox router, not 2.4 or 5.
I then have to go into tv settings to set back to ext...which sometimes works, sometimes doesn't. Former tv had poor wifi cars so I got new tv, which is two small rooms from where router is. No impediments in the way, and 1 story house
Jul 15, 2022Guru - Experienced User
You should be able to go into the tv and delete the old network so its not connecting to it.
Have you tried installing the extender using the installation assistant?
- deesigner2Jul 16, 2022AspirantI don't have an old network. I have a router that cox identifies. Then two netgear ext networks.
Do, network A, the netgear ext2.4 and ext 5 - deesigner2Jul 16, 2022AspirantI don't have an old network. I have a router that cox identifies. Then two netgear ext networks.
So, network A, the netgear ext2.4 and ext 5
