brendabugaloo
Mar 20, 2020Follower
EXT2700 - PURCHASED USED, EXTENDER WILL NOT RESET TO FACTORY MODE
Hello, I am having trouble getting my wifi extender to pop up on my wifi managers on my devices. Only one extender pops up under the name Werkartz I believe and when it is unplugged it does not a...
Mar 20, 2020Guru - Experienced User
brendabugaloo wrote:Hello,
I am having trouble getting my wifi extender to pop up on my wifi managers on my devices. Only one extender pops up under the name Werkartz I believe and when it is unplugged it does not appear. We have attempted to reset it to factory mode 4 different times, holding down the button for 5-10 seconds each time and it still appears as the old name. I cannot connect to it therefore I don't have access to change anything.
I purchased this used on amazon and was wondering if someone could walk me through this.
I hope you are well, kind regards,
Brenda
When you're pushing and holding reset, is the device plugged in? When you've held the reset button long enough, the lights will change. its usually 7-15 seconds but some have needed up to 30 seconds.
