IrnBear
Feb 05, 2022Tutor
Extend Internet to other end of house + garage at back of lot.
Hello, I would like to extend my wifi to other end of house. I tryed one of the Nighthawk Wireless extenders (Netgear WiFi Mesh Range Estender EX7700) wirelessly. All it did was screw up everyone ...
Feb 06, 2022Guru - Experienced User
If you're adding 2 (buying 2) I'd just look at getting a mesh system like netgear orbi or MK nighthawk. they support both wired and wireless backhauls and would allow seamless transition. They've been pretty cheap renewed on amazon lately.
- IrnBearFeb 10, 2022Tutor
Can I continue to use my current Netgear Router and just add the MK Mesh wired boxes. Or do I need to change to the MK router as well?
- plemansFeb 10, 2022Guru - Experienced User
You can add the mk to your current setup. You'd just want to install the MK in access point mode to prevent a double nat
good to know. Thank you for responding.
I went ahead and ordered an actual extender, not one of the mesh extenders.
I got the EX7000 to wire from my router out to the garage.
I got the EX3700 to plug into our bedroom at the opposite side of the house from my office (Router Home)
I hope this is a good choice and decision.
