IrnBear
Feb 05, 2022Tutor
Extend Internet to other end of house + garage at back of lot.
Hello, I would like to extend my wifi to other end of house. I tryed one of the Nighthawk Wireless extenders (Netgear WiFi Mesh Range Estender EX7700) wirelessly. All it did was screw up everyone ...
Feb 06, 2022Guru - Experienced User
If you're adding 2 (buying 2) I'd just look at getting a mesh system like netgear orbi or MK nighthawk. they support both wired and wireless backhauls and would allow seamless transition. They've been pretty cheap renewed on amazon lately.
IrnBear
Feb 10, 2022Tutor
Can I continue to use my current Netgear Router and just add the MK Mesh wired boxes. Or do I need to change to the MK router as well?
- plemansFeb 10, 2022Guru - Experienced User
You can add the mk to your current setup. You'd just want to install the MK in access point mode to prevent a double nat
- IrnBearFeb 10, 2022Tutor
good to know. Thank you for responding.
I went ahead and ordered an actual extender, not one of the mesh extenders.
I got the EX7000 to wire from my router out to the garage.
I got the EX3700 to plug into our bedroom at the opposite side of the house from my office (Router Home)
I hope this is a good choice and decision.
