NWest1965
May 06, 2020Aspirant
Extend WIFI Coverage
Hi Community I have the Nighthawk R8000 plugged into my study which is on one side of my house and as I get towards the far side of my house I lose WIFI coverage almost completely. What is the best...
May 06, 2020Guru - Experienced User
you could use a wifi extender, you could use a powerline device with built in wifi, or you could even use a moca adapter (ethernet over coax).
Several different options for you.
NWest1965
Those are all pretty expensive solutions when I already have a pretty expensive router! Would your EX6250 do the job, but with a little less performance??
Are there any others lower in your range that would also do the job.
- plemansMay 06, 2020Guru - Experienced User
the models I have listed are just my signature. They're not recommendations.
You have multiple options that you can try. I just listed extenders, powerline, or moca adapters.
The ex6250 might work fine for you.
- NWest1965May 06, 2020Aspirant
OK, understood, much appreciated
