Krowhell
Aug 01, 2021Aspirant
Extend Wifi through Ethernet
Hello, I have a Nighthawk X6S Tri-Band Mesh Extender. In my house, the internet router is on level 3, and my Extender is on level 1. I have an ethernet cable between level 1 & level 3. I tried to...
- Aug 03, 2021
I guess I am more looking into 802.11r enabled devices. Is there a way to find the compatible devices on the netgear site ? (I know the R7800 can do it, but I don't see it in the list of its features...) https://forum.openwrt.org/t/solved-802-11r-configuration-details-r7800/61352
Aug 01, 2021Guru - Experienced User
Spoiler
In access point mode, the smart roaming features are disabled on extenders and devices tend to be sticky and not roam as well.
The only devices I know that support wired and/or wireless backhaul are the Orbi series and the MK nighthawk series.
You could use the extender but put it on floor 2. It'd be midpoint and pickup a better signal from the router to rebroadcast.
Krowhell
Aug 03, 2021Aspirant
Thanks for the recommandation, I tried that already, but this is a very old house with thick walls, it would work out if I add an EX8000 at each floor.
So as far as I understand there is no Netgear solution/device which would allow to extend a Wifi, using Ethernet network (beside going with Business solution and a controller for roaming feature), right ?
- KrowhellAug 03, 2021Aspirant
- plemansAug 03, 2021Guru - Experienced User
I don't know of a list of devices with those features
