Ste12
Nov 24, 2020Aspirant
Extend Wifi to connect solar inverters using Netgear R6300 router to extend Nighthawk X4 R7500 wifi
I have been trying to connect my R6300 router to my network which uses the R7500 router but have had such difficulty even though I have found a narrative of a "how to". It sounds so easy reading i...
Ste12
Ihanks for a speedy reply
I've tried wireless and cat 5 but cannot reach the 6300 router login.
I was using the following, hoping to use the Genie as Tomsguide did, but nothing worked the same. So I was reading the one from digitaltrends and got lost.
This is a first attempt at this, obliously. Suggestions would be appreciated.
https://www.tomsguide.com/us/how-to-turn-old-router-into-wifi-extender,review-5166.html
https://www.digitaltrends.com/computing/how-to-extend-wi-fi-range-with-another-router/
Nov 24, 2020Guru - Experienced User
Step 1 in tom's guide: find a compatible router.
the R6300 doesn't have an extender mode. Maybe with 3rd party firmware but not in stock form.
- Ste12Nov 24, 2020Aspirant
Good point,
The 6300 was in a closet from Cox when they changed me to fiber optic and my 7500 was better than their 6300.
What do you think about an extender like a Netgear AC750 or AC1200?
It would be much easier and the outlet is on the wall just inside the inverters.
- plemansNov 24, 2020Guru - Experienced User
Both of those are speeds and not models.
Extenders work pretty good but a lot depends on distance and what materials are between the extender/router. Certain materials block wifi extremely well (cement, brick, concrete, metal siding, foil lined insulation, etc) They need a decent signal to rebroadcast.
Your best bet would be to speed check with a phone where you planned on putting the extender. If you can get decent speeds, then its probably reasonable to do.
Keep in mind, standard extenders (single/dual band) drop throughput 50% just based off how they have to work.
Thanks for the tutorial and the answers.
I will speed test and probably look into a Netgear WiFi Range Extender EX2800. It is cheap enough to try. Plug and push WPS button.
I'll post again when there is something to post.
Thanks again. Happy Thanksgiving, stay safe.
