Ste12
Nov 24, 2020Aspirant
Extend Wifi to connect solar inverters using Netgear R6300 router to extend Nighthawk X4 R7500 wifi
I have been trying to connect my R6300 router to my network which uses the R7500 router but have had such difficulty even though I have found a narrative of a "how to". It sounds so easy reading i...
Both of those are speeds and not models.
Extenders work pretty good but a lot depends on distance and what materials are between the extender/router. Certain materials block wifi extremely well (cement, brick, concrete, metal siding, foil lined insulation, etc) They need a decent signal to rebroadcast.
Your best bet would be to speed check with a phone where you planned on putting the extender. If you can get decent speeds, then its probably reasonable to do.
Keep in mind, standard extenders (single/dual band) drop throughput 50% just based off how they have to work.
