harkelaar
Jan 19, 2021Initiate
extend wifi with 2 EX7000 extenders in serial; is it possible?
My new home has 4 floors (with concrete walls).At the first floor I have my Wan-modem connected to my R7000 AC1900 router. On the second floor I will put an EX7000 (wired) as an range extender. On th...
michaelkenward
Jan 20, 2021Guru - Experienced User
Where possible, consider using Powerline Ethernet to connect hardwired kit.
You can even get powerline with integrated access points to reach remote bits of your mansion. Or you can use a plug as the source for a wired AP.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
