harkelaar
Jan 19, 2021Initiate
extend wifi with 2 EX7000 extenders in serial; is it possible?
My new home has 4 floors (with concrete walls).At the first floor I have my Wan-modem connected to my R7000 AC1900 router. On the second floor I will put an EX7000 (wired) as an range extender. On th...
Jan 19, 2021Guru - Experienced User
So you're going:
R7000-----wire------>EX7000-----wireless------>EX7000
You should be able to do this if you have a decent signal at the 2nd ex7000. The downfall to range extenders is they need a decent signal to pick up and repeat. If the concrete is blocking wifi sufficiently, they don't help a whole lot unless you wire them in.
