zoes
Oct 21, 2011Follower
Extend wireless range by connecting WN604 to DGN3500?
I want to extend the range of my DGN3500 wireless network. Is it possible to connect a wn604 (with a wire) and have both units acting as wireless access points? In the DGN3500 manual a 'point to point bridge connection' is described which _looks_ like what I want.
As a secondary question do you know of any reason why the same thing would not work with a DGN3500 and a Linksys WAP54G?
Zoe
Zoe
1 Reply
- jmizoguchiVirtuoso
yes.
but been both are not same model. I would consider to use different SSID and channelsAs a secondary question do you know of any reason why the same thing would not work with a DGN3500 and a Linksys WAP54G?
makes no different for using 2nd unit connected with ethernet cables. I would use same setup as above
