Aarontography
Dec 06, 2019Follower
Extended is blocking XBOX NAT
2 days ago,my XBOX NAT started showing "Getting info".And doing a NAT test gave a "can't get a teredo ip"from the XBOX.When I connect to the main router,and even my phone,it shows open.And when I con...
Christian_R
Dec 13, 2019NETGEAR Employee Retired
Hello Aarontography,
You may have to port forward the IP address of the extender and the xbox on the router. I would also check for a firmware update on the extender and factory reset to run through the setup assistant again.
Christian
