Sandman160
Mar 18, 2020Star
Extender compatible with ORBI..?
I’ve got an ORBI setup and need to add an extender that allows me to define a separate network name... so adding an extra ORBI satellite isn’t going to work. I was recommended a Nighthawk EX7700 wi...
- Mar 18, 2020
try installing version 1.0.0.206. Factory reset it after the update.
When you set it up, hardwire into the extender for setup. Make sure to disable the mesh/one ssid feature when you set it up.
Mar 18, 2020Guru - Experienced User
The orbi outdoor and orbi voice both have orbi option or extender option. You could set it up in extender option and then if you ever decided to add it into your network, you could.
I've see others who've used the mesh extenders with orbi. you just don't want to run them with the mesh mode working. just as a standard extender.
Sandman160
Mar 18, 2020Star
Thanks for the response. The Orbi outdoor/voice are kind of pricey solutions though.
I was told the EX7700 would work with ORBI as long as it wasn’t in MESH mode. I couldn’t get it working and Netgear support eventually conceded it didn’t work.
- plemansMar 18, 2020Guru - Experienced User
Do you still have it?
What firmware version is on it?
others have gotten it working as well.
Which version of orbi do you have?
- Sandman160Mar 18, 2020StarI can’t remember the firmware version right now but I tried to update it and it said it was up to date.
Does that help?
Netgear talked me into setting up as a mesh router in the last call so it takes the WiFi out if it’s on now.- plemansMar 18, 2020Guru - Experienced User
Does that help?
Netgear talked me into setting up as a mesh router in the last call so it takes the WiFi out if it’s on now.some times the auto update doesn't pull the latest firmware. That's why its always good to check.
and potentially netgear support didn't know about the newest. Do you still have it?
