Sandman160's avatar
Mar 18, 2020
Extender compatible with ORBI..?
I’ve got an ORBI setup and need to add an extender that allows me to define a separate network name... so adding an extra ORBI satellite isn’t going to work. I was recommended a Nighthawk EX7700 wi...
  • plemans's avatar
    Mar 18, 2020
    try installing version 1.0.0.206. Factory reset it after the update.
    When you set it up, hardwire into the extender for setup. Make sure to disable the mesh/one ssid feature when you set it up.
