Sandman160
Mar 18, 2020Star
Extender compatible with ORBI..?
I’ve got an ORBI setup and need to add an extender that allows me to define a separate network name... so adding an extra ORBI satellite isn’t going to work. I was recommended a Nighthawk EX7700 wi...
- Mar 18, 2020
try installing version 1.0.0.206. Factory reset it after the update.
When you set it up, hardwire into the extender for setup. Make sure to disable the mesh/one ssid feature when you set it up.
Sandman160
Mar 18, 2020Star
The nighthawk app is telling me it’s running V1.0.0.188.
Mar 18, 2020Guru - Experienced User
- Sandman160Mar 19, 2020Star
plemans wrote:try installing version 1.0.0.206. Factory reset it after the update.
Thank you for this. After hours on the phone with support, getting nowhere, this seems like good advice.
I've updated the firmware. I didn't reset back to factory settings because as soon as it rebooted it came back working. It connected to the Orbi, got an internet connection extended the network. Doing everything I want it to do.
I've rebooted it and it does seem to be doing everything I wanted.
So, THANK YOU. Much appreciated.
- plemansMar 19, 2020Guru - Experienced User
Glad to hear you got it working! if you mark it as solved it helps the next person find the solution quicker :)
plemans wrote:if you mark it as solved it helps the next person find the solution quicker :)
Done. Thanks again..!
