Alexey88
Dec 01, 2019Follower
Extender connected to main router, but there no internet access
hi dear community! I do have a problem. I was using my EX7300 extender for a year - everything was pefect. suddenly, i met chanllenge with my internet connection. Extender is able to conect to the...
Dec 01, 2019Guru - Experienced User
What firmware is on your extender?
it wouldn't be the first time a firmare update has caused issues.
https://www.netgear.com/support/product/EX7300.aspx
As well as you can try resetting the router back to factory. You didn't put what router it is but occasionally the router is the culprit sometimes.
