Tdraym
Dec 12, 2025Aspirant
Extender connected
I have a ax1600 extender if all for lights are showing steady green is it connected to my main router I have many questions but the last time tried to publish one it wouldn't let so let's start her...
Dec 13, 2025Guru - Experienced User
What router are you connected to?
The EAX12 is a mesh extender so when setup in default setup, it won't show as separate network. Just one.
And if the lights are green, its connected and working.
If you want to access it, log into your router and look at its attached devices page. The extender should be on there with an IP address. Use that address to log into it.
