MisterJenks
Jun 29, 2021Tutor
Extender connection issues. Stuck in factory reset mode.
My extender lost connection a few days ago. I switched the power off, but when I restarted it all of the LED lights on the front are flashing white. The power button light on the back of the extender...
- Jul 06, 2021
Glad to hear it!
If you mark the solution as solved, it might help the next person with that issue (and prevent others burning time on trying to fix)
Jul 02, 2021Guru - Experienced User
Start by pushing and holding reset while the device is powed on. Hold for 7-15 seconds (I've done it for up to 30 seconds)
MisterJenks
Jul 05, 2021Tutor
Thanks. I did this but nothing changed. The extender appears to be stuck in reset mode.
- plemansJul 05, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- MisterJenksJul 06, 2021TutorThanks for your help. Really appreciate it.
The extender is now working- plemansJul 06, 2021Guru - Experienced User
Glad to hear it!
