wayneh2
Mar 04, 2017Follower
extender do i need 300 or 1200 mbps for brighthouse router to stream movies
Am I better off to buy the 1200 mbps or 300mbps extender for streaming movies from brighthouse router?
... and general internet applications.
thanks
wh
Hello wayneh2
It just depends on your budget and the internet connection speed you have the 300 will work fine if your connection is slower than that.
DarrenM
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello wayneh2
DarrenM
