Buck567
Apr 09, 2021Tutor
Extender e2700
My extender was working fine until recently it no longer receives internet. The lights are on the extender, it shows as a WiFi network on my devices, but when I connect to (my network)_ext WiFi netwo...
- Apr 09, 2021
No, for setup the laptop doesn't need to be online. It just needs to be connected to the internet. Thats why I usually recommend disabling the wifi, so the laptop doesn't default back to the wifi connection during setup
Apr 09, 2021Guru - Experienced User
What router do you have?
Are you setting up using wps or using the installation assistant?
- Buck567Apr 09, 2021TutorI have an At&T router. I initially set up the extender either wps (?assume this is wireless). Everything worked fine for many months. Then, all of a sudden, all connected devices are “offline” even though the router and device lights are green on the extender. I have tried to reconnect via Ethernet and the computer, but no success.
- plemansApr 09, 2021Guru - Experienced User
try factory resetting it and then reinstalling using the installation assistant.
- Buck567Apr 09, 2021TutorI have tried that multiple times. I have tried to re-install using wireless and Ethernet. Intermittently I will get the login screen for net gear and proceed through but receive a message that the extender is not connected to the home network. Frequently I am unable to even get the log in screen error says unable to find the page. The light on my extender indicates green and device light is green also, but no internet in any connected device.
