Hike13
Nov 02, 2015Aspirant
Extender EX2700 and Windows 8/10
Hello, I have a wifi externder EX2700 and it worked fine with my laptop with windows 7. But now I bought a HP's all in one with windows 8 and the extender does not work. I am using windows 10 now...
Hike13
Nov 04, 2015Aspirant
The Wif adapter says also "unidentified network" and "no internet acess" when I connect to Netgear's extender after the setup.
Hike13
I also tried to connect my computer and the ex2700 extender through an ethernet cord as you asked, but the problem remains. When I ask the windows to solve the problem the result is:
'Ethernet Doesn't Have A Valid IP Configuration'
- nhannNov 05, 2015NETGEAR Employee Retired
Hi Hike13,
Which router are you using with the EX2700?
Please update the router to latest firmware then reset the router to factory defaults.
Also restart your computer.
If possible try other devices/computers that can connect to the EX2700.
If you have another ethernet cord, try that also to connect from EX2700 to your computer.
- Hike13Nov 05, 2015Aspirant
Hello nhann,
My router's firmware is updated.
And there's no problem there because the EX2700 connects without any problem with my HP notebook. The problem lays when I try to connect the EX2700 with my new HP desktop. When I use a TP Link extender there is no problem also.
When I connect the router to the new desktop using a ethernet cord there is no problem. But if I connect the desktop and the EX2700 using a ethernet cord there is no connection.
So, I believe the problem is the communication between my new desktop and the EX2700, because both ethernet port and wifi adapter from my desktop does not work with the EX2700.
Thanks
- nhannNov 06, 2015NETGEAR Employee Retired
Hi Hike13,
Please confirm these steps as mentioned above:
"Which router are you using with the EX2700?
Please update the router to latest firmware then reset the router to factory defaults."
