xRCGx's avatar
xRCGx
Extender EX3110 / AC750 broken or...?
Hello
So I had my wifi reset remotely by my provider and the wifi name was changed and my extender got disconnected. I reset the extender and connected to NETGEAR_EXT with my phone and attempted to go to the mywifiext, but it will not load. Other devices I connect to it do the same. It is reset and will not allow me to access mywifiext in any way. I cleared my phones cache/data from the browser and still no luck. My devices connect to NETGEAR_EXT and the extender shows its connected but I cannot access mywifiext in order to reconnect it to my wifi. I am wondering if this is an internal problem and the extender is possibly broken or malfunctioning. Please help!
  • You said you were trying to set it up through your phone.
    have you tried a pc/laptop? Or a different browser?
    you can also try the address 192.168.1.250
    that'll be the extenders default ip address when its not setup.
  • plemans's avatar
    1. what router are you connecting it to?
    2. what firmware is on the extender?
    3. you factory reset the extender? Pushed and hold reset for 7-15 seconds while powered on?
    4. did you try a different pc or different browser?
    • xRCGx's avatar
      xRCGx
      1. The router I am connecting to is a Mediacom hitron modem/router combo. The extender had been working for months off of it, until the modem/router was reset remotely by Mediacom, and they changed the wifi name from upper case to lower case.
      2. I am not familiar with firmware or how to check this, as the extender has no plugs. It is wireless only.
      3. Yes. It is now seen as NETGEAR_EXT.
      4. Yes. No matter the device connected to my extender, it will not display the local network set up page.
      • plemans's avatar
