PantherTank
Oct 03, 2021Aspirant
Extender ex6100v2/AC750 ONLY GREEN POWER LIGHT ON.
Hello, my extender is not working, only green power light is on. I have had the extender for a couple of years with no issues. Have tried factory reset with power off and then saw a post saying you h...
Oct 03, 2021Guru - Experienced User
Did you try hardwiring a pc/laptop into it and setting it up using the installation assistant?
- PantherTankOct 03, 2021Aspirant
I did what you said and it goes to the setup screen. It asks me to select an existing network I would like to extend. It scans for a network, it finds the one I want, i select it and then there are two buttons BACK and NEXT but I can't select NEXT it is greyed out
- plemansOct 04, 2021Guru - Experienced User
If you didn't fill in all the fields, it doesnt' let you advance.
did you fill them all in?
Have you tried a different browser/pc?
