Bongoben5
Feb 27, 2023Aspirant
Extender EX6110 set up
Hello Hoping someone can help. I have just bought the above extender. I have successfully connected it to my home router (using WPS) however, I'm unable to connect any of my devices to the extend...
Bongoben5
Mar 01, 2023Aspirant
Thank you for your reply. Unfortunately, I'm still stuck. I did the following.
1 Reset. Power light shows green.
2 Connect (iphone) to NETGEAR_EXT. Power light green, device light green. 'No Internet Connection' Message on device. I understand this is normal.
3. Typed the mywifiext address into the browser on my iphone. Message that 'Safari cannot open the page because not connected to the server' appears on phone. I can go no further this way.
I've also tried accessing the mywifiext website when connected to my router but not connected to NETGEAR_EXT. I'm directed to a NETGEAR page which tells me I'm not connected to my extender's wifi network, as expected. Scrolling down takes me to an option for MAC OS X or IOS (which I assume is right) mywifiext.local. If I select the link, I just get a blank screen indicating an inability to connect.
I'm really not sure where to go next. Any suggestions gratefully received.
Mar 01, 2023Guru - Experienced User
Try it not using an iOS device.
See if a windows pc/laptop will work
