Pet82
Sep 30, 2022Follower
Extender EX6120
I can’t get my NETGEAR Wi-Fi Range Extender EX6120 to work with my Xfinity xFi Advanced modem. I have done factory reset and still will not work
Oct 01, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
