Marigio
Feb 16, 2021Tutor
Extender EX7000 2.4 GHz Problemi di connessione
Ho un extender EX7000 con attive entrambe le frequenze. Per quanto riguarda la 5GHz non ci sono problemi. Per la 2,4 GHz devo continuamente riavviare l'extender perchè ci sia connessione, ma dopo p...
Feb 16, 2021Guru - Experienced User
What router is it connected to?
Did you install it using WPS?
Marigio
Feb 16, 2021Tutor
The extender is connected to a Netgear D7000v2 bought guessing the best match...
Yes, I installed it with WPS and the "help" of Netgear Genie.
- plemansFeb 16, 2021Guru - Experienced User
The backbone of the system is the router. I don't have the d7000v2 but i haven't heard great things about it. Might be worth trying to install it using the installation assistant.
- MarigioFeb 16, 2021Tutor
The D7000v2 router, gave to me some problems, but now it seems working...
I Bougt it because I had some problems with my old N300 (great for me...) and the EX7000. The problem, may not be the N300...
I installed the D7000v2 with the Netgear help and, the devices connected directly to the route (no via extender) are running well.
I wouldn't throw away the Netgear couple and their cost... I hope for a solution before (if it's possible).
The photo show the PC in the direct range of D7000v2, non problem
