Huiskesmartijn
Sep 04, 2020Aspirant
Extender EX7700 connection problems with R7000
Hi, So I recently purchased the Nighthawk X6 EX7700 as a range extender for my Nighthawk R7700 router. I'm running into a lot of problems though. I can set everything up without problems, and the...
Huiskesmartijn
Sep 05, 2020Aspirant
EDIT: The problem now also occurs on the 2.4GHz network.
After some more research, I found that the only way to get devices connected properly is by manually setting the IP address and dns. But while this sounds like a DHCP issue, the extender obviously does not have DHCP and the router DHCP is working fine (tested with the extender turned off).
This is very inconvenient as every time I connect a new device I need to set its IP manually, and for some devices like my tv this is not even possible.
Kkhan786
Oct 18, 2020Aspirant
I made the mistake of buying a second router so have now spent a total of £220. I’m so annoyed this is clearly an issue for the product. Thank you for the person describing the problem as I could not have done that.
netgear - please help. Please replace with models that work.
