Poetryking
Aug 18, 2021Aspirant
Extender for use Netgear R7450
I need to extend the range in my house. What is the best way (and cost effecient) to extend the range of my router to a garage 100 feet away?
Poetryking
If we only needed to go 50 feet, is there a plug and play extender that works well with this router?
Aug 18, 2021Guru - Experienced User
It all depends. Its not always about distance.
If the home's exterior wall is brick and the shed, it might be blocked 100%.
Certain materials block wifi better than others. And an extender still needs a signal.
Stand where you think the extender will be with your phone and see if you can get a usable signal.
If you don't, the extender won't either.
