Koomikko
May 27, 2014Follower
Extender makes router ssid to dissappear
I'm turning to you all for help. I have a cable modem (moyorola) which is connected to a wireless access point (aztec). Within 5 meters I have placed wn1000rp. Most of the time this combo works fi...
storm_2003
Jul 25, 2014Novice
Please change the channel of the extender or the router.
To select the best channel, use inSSIDer software on your computer.
This software can detect all the wireless signal available on your location including the security type and the channels used even the signal strength.
This might help you. http://www.inssider.com/
