KamleshR
Apr 07, 2023Tutor
Extender N300
recently I changed my network provider and and even after resetting factory settings the extender does not recognise the new password. I have model WN3000RPv3 and the new network is recognised but c...
Apr 09, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
