ThatITGuy8914
Mar 28, 2021Initiate
Extender Network Switch
Instead of using WPS to have the Main Router and EAX20 Mesh Extender connect; can they work together via CAT6? I have a CISCO switch behind my AC1900 Router that runs to RJ45 jacks throughout my home....
- Mar 28, 2021
If you hardwire in the extender, you'd need to rerun setup and set it up in access point mode.
https://www.netgear.com/support/product/eax20
Mar 28, 2021Guru - Experienced User
- ThatITGuy8914Mar 28, 2021InitiateThank you, I see that in the user manual on setup as an access point. Thank you!!
- plemansMar 29, 2021Guru - Experienced User
Let us know if you have any other issues and we're happy to help
