JamiePMacdonad
Apr 07, 2020Tutor
Extender not able to connect to your existing network
Hi, Model EX6120. AC1200 WiFi range extender serial no. 4D5B937EA143B We have changed our router due to additional devices being used in the home, this is what our provider suggested. I have tried all...
Apr 07, 2020Guru - Experienced User
What router are you connecting to?
Firmware on the extender?
have you tried changing the password on the router?
JamiePMacdonad
Apr 08, 2020Tutor
Hi,
The router is a Technicolor DWA0120.
The extender is only a year old.
Not sure how to change the routers password.
- plemansApr 08, 2020Guru - Experienced User
I've read a few posts that report technicolor routers struggle with wps setup on extenders.
Try the installation wizard for setup.
https://www.youtube.com/watch?v=yJVklshxBMk
You can also log into the router (see the router's manual) and change your wifi password if needed
- JamiePMacdonadApr 08, 2020TutorHi,
Thanks for your response, I’ve tried the installation wizard a few times and it still comes up with the same fault of not being able to connect to the network.
I’ll try changing the routers password, to see if this helps.
