XMalibu101
Jul 12, 2021Initiate
Extender not connecting X4S 7500
I currently have a MR60 Mesh wifi setup in my house. Needed to extend wifi downstairs but couldn't buy just one extender of the MR60. I was sold a X4s 7500 tri band Mesh extender. I cannot get it...
Jul 12, 2021Guru - Experienced User
it doesn't integrate with the system but you should be able to connect it.
don't use wps for setup since it doesn't fully integrate.
Factory reset the extender and then install it using the installation assistant. Not wps or the app.
XMalibu101
Jul 13, 2021Initiate
Thank you Plemans....works a treat now. Cheers:smileyhappy:
- plemansJul 14, 2021Guru - Experienced User
Glad it working for you!
