Designed4Ewe
Sep 01, 2014Initiate
Extender not showing on network list
I plugged in my WN2000RPTv2 and it shows as green. I pressed the WPS button and went to my router, but it doesn't have a WPS button. (I have a Netgear RangeMax WNR834B routher and a Telephony modem). ...
nhann
Nov 02, 2015NETGEAR Employee Retired
Hi Jimbo888,
Which router model are you using with the extender?
Please check if the router is Broadcasting its SSID.
Please also try to configure the 5ghz to different channels and modes.
Here is an example of a NETGEAR router settings page
Jimbo888
Nov 03, 2015Tutor
When I open netgear genie My wireless connections does not list 5Gext . So I cannot config. as your example shows . It only lists my Router , and 2Gext. I must say again everything works with my extender 6100, On any portable device it lists all 3 , my router SSID # , 2Gext , and 5Gext . They all work the only problem is the 5Ext is open and not secure. My PC does not list 5Ext as a connection option, and netgear genie does not list the 5Ext. Only my SSID # and 2 Gext.All I am trying to do is secure ther 5Gext.
- nhannNov 03, 2015NETGEAR Employee Retired
Yes, please confirm which router model you are using.
Can you also confirm which NETGEAR genie you are using? Is it the web browser version? (routerlogin.net) or is it the Genie app that you can download here.
You can also post a screenshot of what you are seeing in your settings.
Thanks
