mooney201's avatar
mooney201
Follower
Jul 10, 2020
Extender password
My router wifi shows password protected. However, my extender does not show a password protect. How can I fix this? MacOS15
  • plemans's avatar
    Jul 10, 2020
    You can log into the extender and setup wireless security.
    If you go to netgear.com/support/   type in your model number. It'll have the manual that walks you through the wireless settings.
