tkpassmore
Sep 10, 2023Aspirant
Extender Recommendations for RAXE500 router
I have a 2 story older house. The router is located downstairs near the middle of the house. Wi fi connection downstairs is excellent. Upstairs Wi-Fi conn is inconsistent. I need recommendations on an...
Sep 10, 2023Guru - Experienced User
Thought not 6Ghz supporting, the EAX80 would work best.
tkpassmore
Are there any that would support 6GHz?
- FURRYe38Sep 10, 2023Guru - Experienced User
Not currently.
No idea if or when NG may come out with something.
- BartleyOct 10, 2023Aspirant
This extender supports 6ghz. I live in an older house and I am currently using three of these with my router. (have a lot of smart devices). I am using an ethernet for the backhaul so the EAX20 is in access mode.(using smart connect) I believe if you use Wi-fi for the backhaul it will use the 6ghz.
Thanks
Gary
- FURRYe38Oct 10, 2023Guru - Experienced User
There is no EAX series extender that supports 6Ghz. They only support AX mode...WiFi 6
