jhird1000
Apr 03, 2022Follower
Extender wont connect to my starlink wifi router
My extender wont connect to my starlink router. Any ideas out there?
Apr 04, 2022Guru - Experienced User
What happens?
What method of setup are you using? Wps or the installation assistant?
If you tried wps, try factory resetting it (push and hold reset for 7-15 seconds while powered on) and then try the installation assistant.
Heres a video of how to use it.
