bigredguy
Feb 23, 2020Follower
Extender won't connect to new Sparklight modem
Just updated my 15 year old modem from (formally Cableone) to a brand new Sparklight CODA-6010 and they won't talk to each other. Ofcourse that means my phone app won't talk to the extender either. ...
Feb 23, 2020Guru - Experienced User
I couldn't find a modem by coda-6010. sure thats the model number or got a link to its site?
Did you try factory resetting the EX8000 and then going through the installation wizard and not using wps?
Some isp modem/routers have a "smart connect" that needs to be disabled to add an extender. Without a manual/specs for the sparklight, I'm unsure what it has for management.
I'd try with resetting the extender (push and hold reset while the extender is fully powered on. Usually around 7-15 seconds). The try using the installation wizard (not wps).
You can find the manual/guide here:
https://www.netgear.com/support/product/EX8000
